different dns for for different users on different times
hi guys,
we are using OpenDNS to block certain sites. how to implement this?
  1. Certain “privilege users” must passthru a another DNS like google.
  2. Force all other users to use OpenDNS during office ours and use GoogleDNS on non office hours.
Please help.
thanks,
OcaVid
Forward it to IT, recline chair, sip lemonade.
This is an IT problem, not a Network issue. This should be enforced on each account or PC with domain services or group policy; it would be unenforceable otherwise.
I’ve solved similar request in this way:
  • set Google dns for all (static dns on pc, dhcp assigned,..)
  • set OpenDns dns on MT
  • create a address-list for privileged/bypassed dns users
  • create a firewall dns redirect for all but exclude the privileged address-list
Normal user dns request is redirected to MT (asked to Opendns), privileged user will bypass dns trick (Google).
Finally ..enable/disable the redirect rule on schedule.
(Beware ..this doesn’t work for cached dns; when schedule enable redirect rule, your users can still use the (eventual) previously cached dns response ..untill the ttl die. I mainly use this schema when dns filters are permanent and it works well)
