Different IPs - same port number
I have two RB750GL both running 5.2 place in two different locations with different WAN IP, in fact I am using DYNDNS.
To each LAN I have connected a camera using the same port number, i e 50999, and I have NATed so that I can access these cameras from the internet giving the URLs ‘http://name-A.dyndns.org:50999’ and ‘http://name-B.dyndns.org:50999’ respectively. Usually I access these camera through a third RB750GL running the same software. This works fine.
But when I am connected locally to one of the LANs I am not able to connect to the camera on the other remote site, for instance when I am connected to the LAN A and gives the URL for camera on site B I only get the camera on site A.
It seems that no matter what IP I use, I only access the local camera given I use the correct port number.
I must have done something wrong, but I cannot see what…!
