Hello all, at my parents home i have an RB2011UiAS-RM that do CAPsMAN for 2 hAP ac2, when i change something on the CAP interfaces on the RB2011 log i see that the output power of the 2.4 and 5 Ghz wlan is the same for the 2 hAP ac2, 30 dB, for 2.4 and 23 dBm for 5 Ghz, but when i log in into the two ac2 one of that (the one powered via PSU) show that the wlan are correctly set to 30/23 dBm, in the other ac2 (the one powered via POE) show that the output power is 3 dDm less then the other, 27/20 dBm, why? what is the correct output power?
Here my CAPsMAN config, the one that show a less output power is the device numbered 2 in Interface Name, is possibile that the output power is less when device is powerd via POE?
all devices has 6.48 ROS
/caps-man channel
add band=2ghz-b/g/n control-channel-width=20mhz extension-channel=XX frequency=\
2412 name=CH1
2417 name=CH2
2422 name=CH3
2427 name=CH4
2432 name=CH5
2437 name=CH6
2442 name=CH7
2447 name=CH8
2452 name=CH9
2457 name=CH10
2462 name=CH11
2467 name=CH12
2472 name=CH13
add band=5ghz-n/ac control-channel-width=20mhz extension-channel=XXXX \
frequency=5180 name="5 CH36"
frequency=5200 name="5 CH40"
frequency=5220 name="5 CH44"
frequency=5220 name="5 CH48"
frequency=5260 name="5 CH52"
frequency=5280 name="5 CH56"
frequency=5300 name="5 CH60"
frequency=5320 name="5 CH64"
frequency=5500 name="5 CH100"
frequency=5520 name="5 CH104"
frequency=5540 name="5 CH108"
frequency=5560 name="5 CH112"
frequency=5580 name="5 CH116"
frequency=5600 name="5 CH120"
frequency=5620 name="5 CH124"
frequency=5640 name="5 CH128"
frequency=5660 name="5 CH132"
frequency=5680 name="5 CH136"
frequency=5700 name="5 CH140"
/caps-man security
add authentication-types=wpa-psk,wpa2-psk encryption=aes-ccm,tkip \
group-encryption=aes-ccm group-key-update=5m name=security1 passphrase=\
HIDDEN
/caps-man interface
add arp=enabled channel=CH11 channel.frequency=2462 configuration.country=\
no_country_set configuration.distance=indoors configuration.hw-retries=4 \
configuration.installation=indoor configuration.mode=ap \
configuration.multicast-helper=full configuration.ssid="HIDDEN" \
datapath.bridge=BRIDGE-LAN datapath.client-to-client-forwarding=yes \
datapath.local-forwarding=yes disabled=no l2mtu=1600 mac-address=\
HIDDEN master-interface=none mtu=1500 name=\
"1 - 2.4 GHZ" radio-mac=HIDDEN radio-name=\
HIDDEN security=security1
add arp=enabled configuration.country=italy configuration.distance=indoors \
configuration.hw-retries=4 configuration.installation=indoor \
configuration.mode=ap configuration.multicast-helper=full \
configuration.ssid="HIDDEN" datapath.bridge=BRIDGE-LAN \
datapath.client-to-client-forwarding=yes datapath.local-forwarding=yes \
disabled=no l2mtu=1600 mac-address=HIDDEN master-interface=none \
mtu=1500 name="1 - 5 GHZ" radio-mac=HIDDEN \
radio-name=HIDDEN security=security1
add arp=enabled channel=CH2 channel.frequency=2417 configuration.country=\
configuration.multicast-helper=full configuration.ssid=HIDDEN \
HIDDEN master-interface=none mtu=1500 name="2 - 2.4 GHZ" \
radio-mac=HIDDEN radio-name=HIDDEN security=security1
mtu=1500 name="2 - 5 GHZ" radio-mac=HIDDEN radio-name=\
/caps-man manager
set enabled=yes
