The users of the hotspot should get 10Mbps on local addresses 192.168.1.0/24 and 10.1.0.0/24.
When accessing all other (WAN) the profile set in usermanager should apply.
How would I achieve this?
Need a good explanation as I`m a novice.
remove 192.168.1.0/24 and 10.1.0.0/24 & use only 10.0.0.0/8 so every user will be on same subnet & they will get around 100mbps speed from each other if ur lan is not seprated through vlan
LAN → IP in Simple Queue -gets speed set in simple queue
IP in Simple Queue → LAN -gets speed set in simple queue
LAN → ALL other IP -gets speed set in profile User Manager
ALL other IP → LAN -gets speed set in profile User Manager
