I got a RB433AH where I have enabled webproxy to restrict web access.
I have some tenants that have internet thru me. They have their own router connected to mine via cable on the 2. ethernet port.
I want to prevent them for downloading torrents and want to use these settings: http://gregsowell.com/?p=894
But I do not want to block my computer that is also connected with cable to the 1. ethernet port.
How can I set up the webproxy different on 2 different interfaces?
Any ideas and suggestions is much appreciated!
I’m new to mikrotic and RouterOS, so please have patience!
Hi
you cant config web-proxy for each interface.
i think if you use /ip proxy access for filter your clients and don’t want to limit your laptop ip in proxy create a accept rule in /ip proxy access for src-address of your laptop
for example:
/ip proxy access add src-address=192.168.1.10 action=allow
for torrent download in rules you are created on /ip firewall set in interface to ether2 then your laptop can download torrents
Have been trying this for a while now, but nothing works.
I have followed the guide on the page I linked to, and tried to add /ip firewall set in interface to ether2, even tried to add src-adress=“subnet for tenants” instead, but no luck.
