is it possible to have different WEP key on each customer in the wireless interface?
Thanks in advance
Christos Ioannou
Thanks in advance
Christos Ioannou
You would have to create a virtual AP interface for each customer also.
You can set a different WEP key for each station in the access list. You don’t have to use virtual ap’s although it is possible to do it that way.
-Gerard
i tried doing that (the acl list part) and it doesnt work.
i set a private key like so and it doesnt care even if the user has a different key it still allows him to connect
2 ;;; tester
mac-address=00:02:6F:4D:AA:FA interface=wlan1 signal-range=-120.120
authentication=yes forwarding=no ap-tx-limit=0 client-tx-limit=0
private-algo=40bit-wep private-key="0002647299"
private-pre-shared-key=""
i would love it if someone can shed some light on this as i really need each user to have his/her own key.
