Different WLAN with CAPsMAN
Hello everyone,
I recently decided to replace my last bit of network (Unifi) with Mikrotik Audience for WLAN coverage.
Currently I am setting up my 10 Gbase-T switch (CRS312-4C+8XG-RM) to act as my CAPsMAN controller for this an probably another WLAN device.
So far I created my three different WLAN SSIDs - each with a different VLAN tag and there I have some questions:
  1. VLAN Mode: is “use tag” the right one or should I select “use service-tag”?
  2. Each WLAN network should have a dedicated ACL. I managed doing this via “Access List”, added all the MAC addresses and the SSID to “SSID Regexp”. Is this the right approach?
    Should there be a “deny any” at the bottom of the ACL?
  3. Two WLANs should be authenticated via an external RADIUS server while the 3rd one should be authenticated by a WPA2 PSK.
  4. I would like to have a separated 4th WLAN for guest access which I can manage via User Manager. I already installed this specific package on my switch but all the “how-to” tutorials I have found online seems to be outdated.
    Can anyone guide me how to set up a voucher-based hotspot manager?
    Is it in general possible to use external RADIUS for WLAN 1 & 2 while using the user manager RADIUS for the guest WLAN? I have not found any option to configure that.
    Thanks in advance!
Audience works MUCH better with the WAVE 2 drivers.
Forget about caps-man and configure the unit standalone. I got downloads in the 400+ range.
Thanks for the advice - I already found help on Reddit.
The thing in general is that I do not need a very high bandwith as only my mobile phone + sometimes a laptop is connected to it.
I just wanted to have a 2.4 & 5 GHz within one device and the regular disk APs were already sold-out on Amazon.
