dke
August 22, 2022, 11:15am
1
is there a proper way to differentiate between RouterOS v6.x and v7.x in a configuration script?
I tried
/system resource
:global versionStr [get value-name=version]
:if ([:pick $versionStr 0] < 7) do={
/log info "Found RouterOS v6.x."
/system ntp client
set enabled=yes primary-ntp=192.168.144.210
} else={
/log info "Found RouterOS v7.x."
/system ntp client
set enabled=yes servers=192.168.144.210
/system ntp server
set enabled=yes
but RouterOS seems to parse the contents inside the if-brackets despite not going inside, so that it then throws the error, as the
primary-ntp
key is no longer available:
expected end of command (line 4 column 19)
Thanks,
Daniel
You probably need something like this:
:do {[:parse "/system ntp client set enabled=yes primary-ntp=192.168.144.210"]} on-error={}
Jotne
August 22, 2022, 5:12pm
3
I do use this to test if RouterOS is 7 or other
:if ([:tonum [:pick [/system resource get version] 0 1]] > 6) do={
This runs if Router os is 7.x+
} else={
This part runs if Router is is 6 .x or lower
dke
September 8, 2022, 2:46pm
4
Working, thank you very much!
Complete, corrected script:
:global versionStr [/system resource get version]
} else={
:do {[:parse "/system ntp client set enabled=yes servers=192.168.144.210"]} on-error={}
:do {[:parse "/system ntp server set enabled=yes"]} on-error={}
Jotne
September 8, 2022, 3:42pm
5
From what I have learned from rextended , you should avoid on-error.
Find out what can go wrong and make a script that will not fail.
Maybe rextended will help out.
sid5632
September 9, 2022, 12:16am
6
You clearly didn’t read or understand the question then.
There is a syntax difference between V6 and V7. You CAN’T make something that won’t fail, except as already stated.
It is not sufficent to ckeck only RouterOS version with (s)NTP…
This is just the example for check, not for bypass syntax checking.
/system resource
:global rosVer [:tonum [:pick [get version] 0 1]]
:if ($rosVer~"(6|7)") do={
:if ($rosVer = 6) do={
:put "Detected RouterOS 6"
/system package
:if ([:len [find where name="ntp"]] = 1) do={
:put "with NTP package installed"
} else={
:put "without NTP package installed, use SNTP"
:if ($rosVer = 7) do={
:put "Detected RouterOS 7"
:put "the NTP package is always present"
} else={
:put "Unrecognized RouterOS version: >$rosVer<"
And this is the code without the “onhorror-resume-next”
/system resource
:global priNTP 0.0.0.0
:global secNTP 0.0.0.0
:local setNTP ""
/system package
:set setNTP "/system ntp client set enabled=yes primary-ntp=$priNTP secondary-ntp=$secNTP; \
} else={
:set setNTP "/system ntp client set enabled=yes primary-ntp=$priNTP secondary-ntp=$secNTP"
:set setNTP "/system ntp client set enabled=yes servers=$priNTP,$secNTP; \
:execute "$setNTP"
} else={
