Hi! I’m new to using mikrotik routers and am having some difficulties with the port forwarding..
I’m trying to forward some ports to a server I own, while I have been able to add a rule in the firewall for allowing people outside of my local network to connect to my services, I myself inside the same network can’t seem to connect no matter what I try.
I read the guide for Hairpin NAT’s and added the rule it suggests and still no luck.
I’m really rather at the end of my rope on this one, it’s got me stumped something fierce I’m afraid..
Here is a pastebin of my config file, maybe someone could take a look and see what’s up.
http://pastebin.com/WLuLtsFJ
Also nice to meet you all!
I replaced the pastebin so if someone could remove the comment above that’d be great ^^
And since the first comment was post the whole conf, here it is:
jan/02/1970 00:38:10 by RouterOS 5.26
software id = CCC3-Z64V
add admin-mac=D4:CA:6D:0F:32:EB auto-mac=no l2mtu=1598 name=bridge-local
protocol-mode=rstp
/interface wireless
set 0 band=2ghz-b/g/n channel-width=20/40mhz-ht-above disabled=no distance=
indoors l2mtu=2290 mac-address=C8:D3:A3:05:FD:E8 mode=ap-bridge name=WLAN
ssid=Lexie wireless-protocol=802.11
set 0 name=WAN
set 1 name=LAN
set 2 master-port=LAN name=ether3-slave-local
set 3 master-port=LAN name=ether4-slave-local
set 4 master-port=LAN name=ether5-slave-local
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys
wpa-pre-shared-key=notmyrealpassword wpa2-pre-shared-key=
notmyrealpassword
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m
add name=dhcp ranges=192.168.0.100-192.168.0.254
add address-pool=dhcp disabled=no interface=bridge-local name=default
add bridge=bridge-local interface=LAN
add bridge=bridge-local interface=WLAN
add address=192.168.0.1/24 comment="default configuration" interface=
bridge-local
/ip dhcp-client
add comment="default configuration" disabled=no interface=WAN
/ip dhcp-server lease
add address=192.168.0.101 disabled=yes mac-address=50:E5:49:47:D8:AF
add address=192.168.0.106 mac-address=00:21:97:C4:61:AF
add address=192.168.0.0/24 gateway=192.168.0.1 netmask=24
add address=192.168.88.0/24 comment="default configuration" dns-server=
192.168.88.1 gateway=192.168.88.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=established
add chain=input comment="default configuration" connection-state=related
add action=drop chain=input comment="default configuration" in-interface=WAN
add chain=forward comment="default configuration" connection-state=established
add chain=forward comment="default configuration" connection-state=related
add action=drop chain=forward comment="default configuration" connection-state=
invalid
add action=masquerade chain=srcnat comment="default configuration"
out-interface=WAN to-addresses=0.0.0.0
add action=dst-nat chain=dstnat comment=Minecraft dst-port=25565 in-interface=
WAN protocol=tcp to-addresses=192.168.0.106 to-ports=25565
add action=masquerade chain=srcnat dst-address=192.168.0.106 dst-port=25565
out-interface=bridge-local protocol=tcp src-address=192.168.0.0/24
add action=dst-nat chain=dstnat comment=HTTP dst-port=80 in-interface=WAN
protocol=tcp to-addresses=192.168.0.106 to-ports=80
add action=masquerade chain=srcnat dst-address=192.168.0.106 dst-port=80
/ip neighbor discovery
set WAN disabled=yes
set WLAN disabled=yes
/system leds
set 0 interface=WLAN
/system routerboard settings
set cpu-frequency=400MHz
/tool mac-server
add disabled=no interface=LAN
add disabled=no interface=ether3-slave-local
add disabled=no interface=ether4-slave-local
add disabled=no interface=ether5-slave-local
add disabled=no interface=WLAN
add disabled=no interface=bridge-local
/tool mac-server mac-winbox
add interface=LAN
add interface=ether3-slave-local
add interface=ether4-slave-local
add interface=ether5-slave-local
add interface=WLAN
add interface=bridge-local
Edit yourself the first post, or the password “…volvo…” embedded on pastebin is clearly visible…
Later I check the config, also other users can do.
kaizokuj:
I already did that.
NOT
on pastebin are available:
This paste has a previous version, view the difference.
I actually did not know that pastebin had that feature, fixed now.
