Difficulty to interconnect two CCR16
I have a problem with interconnect two CCR16.
The first CCR16 has the following settings:
ether 1 - 177.39.3.1/24
pppoe-out1 - a public IP for my provider
Network 10.0.0.0/8 - I have about 95 VPN’s with this range and routes manually created withihin each RB750 pointing to the 177.39.3.0.
This first Mikrotik is responsible for an operation that I have from 95 client connected in my company.
The second CCR16 is my router adm, for network office.
Has the following settings:
ether 1 - 192.168.0.1/24
ether 2 - a public IP for my internet provider, different for the first MK.
What I need is to access the VPN’s of the first Mikrotik on the 10.0.0.0/8 network through the 192.168.0.1/24 network.
I do not have active firewall rules that can block this connection and I set up a link IP to tie the two devices using IP’s:
10.57.10.2 MK1
10.57.10.1 MK2
What settings do I need to perform the most so that access works normally?
Do I need to make routes?
I managed to hit some routes between the networks.
