Direct attach cable question
Hey guys,
We have multiple ccr’s that run in our network.
Our edge router is a Cisco and we use the CCR’s for distribution.
The ccr’s are in turn connected to a Bdcom s5612 switch via 3m direct attach cable that we purchased from mikrotik. The Bdcom switch has 12x10g ports and 8x1g ETH ports.
What I’d like to know if there are any known connectivity compatibility issue since the two ends of the cable aren’t both mikrotik devices. Even though all ports are 10g, we see a decline in service once a CCR goes over 1.3g. CPU usage on the CCR ranges from 25% to 40%.
Any help would be greatly appreciated.
Best regards,
Niamul
Yeah, it works with Bdcom 5612 switch
You guys might want to check out their switches, 12x10g ports, 8 ETH 1g port with 180gbps back plane at about 2k usd
Did you solved decline in service on high traffic towards ccr?
