Disable ARP on interface and ipv6 stops working
I have a test network with a couple of routerboards (ROS 5.6). I am running just ipv6 on these routers no ipv4. When I try to set all the interfaces to arp=disabled all ipv6 local connections on the lan fail. I can’t ping, winbox to the ipv6 ip. When I mac winbox into a device I see in the ipv6 neighbor list the other ipv6 addresses say status “incomplete” then “failed”.
Is arp required on 5.x for ipv6 to work? From what I have read ipv6 doesn’t need arp because it uses icmp6 to do neighbor discovery. I’m still looking at wireshark packet captures and it looks like the devices are exchanging icmp6.
Has anyone else run into this? Any suggestions?
ARP is an IPv4 protocol, and is unnecessary for IPv6. I don’t see how even a bug would make it possible for IPv6 to rely on ARP. IPv6 and IPv4 are like ships in the night, they don’t know about each other at all.
I’ve tried disabling ARP and I can’t reproduce your problem between an RB750G and an RB433, both running 5.6. Here the devices:
[felix@rb433] > /system resource print
                   uptime: 19h5s
                  version: 5.6
              free-memory: 49908KiB
             total-memory: 62196KiB
                      cpu: MIPS 24Kc V7.4
                cpu-count: 1
            cpu-frequency: 300MHz
                 cpu-load: 1%
           free-hdd-space: 29468KiB
          total-hdd-space: 61440KiB
  write-sect-since-reboot: 158
         write-sect-total: 398070
               bad-blocks: 0%
        architecture-name: mipsbe
               board-name: RB433
                 platform: MikroTik
[felix@rb750g] > /system resource print
                   uptime: 19h38s
                  version: 5.6
              free-memory: 16588KiB
             total-memory: 29708KiB
                      cpu: MIPS 24Kc V7.4
                cpu-count: 1
            cpu-frequency: 680MHz
                 cpu-load: 2%
           free-hdd-space: 32072KiB
  write-sect-since-reboot: 1202
         write-sect-total: 2224448
               bad-blocks: 0%
               board-name: RB750G
                 platform: MikroTik
I’ve turned off ARP on all the RB433 ethernet interfaces, as well as the RB750G interface that serves as the RB433 uplink:
[felix@rb433] > /interface ethernet print
Flags: X - disabled, R - running, S - slave
 #    NAME        MTU MAC-ADDRESS       ARP        MASTER-PORT      SWITCH
 0 R  750        1500 00:0C:42:77:95:97 disabled
 1    ether2     1500 00:0C:42:77:95:98 disabled   none             switch1
 2    ether3     1500 00:0C:42:77:95:99 disabled   none             switch1
[felix@rb750g] > /interface ethernet print where name=433
 2 R  433        1500 00:0C:42:70:12:9A disabled   none             switch1
Here’s an IPv6 address on a loopback on the 433:
[felix@rb433] > /ipv6 address print where interface=loopback0
Flags: X - disabled, I - invalid, D - dynamic, G - global, L - link-local
 #    ADDRESS                                     INTERFACE           ADVERTISE
 0  G fd8a:ed9a:41f5:ffff::2/128                  loopback0           no
I can ping that from the RB750G, as well as from a laptop behind a different port on the RB750G:
[felix@rb750g] > /ping fd8a:ed9a:41f5:ffff::2 count=4
HOST                                     SIZE TTL TIME  STATUS
fd8a:ed9a:41f5:ffff::2                     56  64 0ms   echo reply
    sent=4 received=4 packet-loss=0% min-rtt=0ms avg-rtt=0ms max-rtt=0ms
$ ping6 -c 4 fd8a:ed9a:41f5:ffff::2
PING6(56=40+8+8 bytes) 2001:1938:2d2:1:b103:fc48:e2ae:c503 --> fd8a:ed9a:41f5:ffff::2
16 bytes from fd8a:ed9a:41f5:ffff::2, icmp_seq=0 hlim=63 time=1.643 ms
16 bytes from fd8a:ed9a:41f5:ffff::2, icmp_seq=1 hlim=63 time=1.686 ms
16 bytes from fd8a:ed9a:41f5:ffff::2, icmp_seq=2 hlim=63 time=1.735 ms
16 bytes from fd8a:ed9a:41f5:ffff::2, icmp_seq=3 hlim=63 time=1.765 ms
--- fd8a:ed9a:41f5:ffff::2 ping6 statistics ---
4 packets transmitted, 4 packets received, 0.0% packet loss
round-trip min/avg/max/std-dev = 1.643/1.707/1.765/0.047 ms
Granted, I didn’t turn off ARP on ALL interfaces on the RB750G, but it’s off on the RB433 completely (and IPv4 did stop working) as well as its uplink on the other side.
I did get interface flaps when changing ARP modes on the interfaces, it looks like the router tears down the interface on a PHY level, changes the setting, and then brings it back up. The logs show the interface going down and then back up, and the routing protocols between the two routes converging again. Is it possible that when you changed ARP modes for some reason the interfaces just stayed down on PHY and never came back up? Do you have console access to both routers to check interface status?
fewi I’m having a similar problem but instead of disabling arp i put the interface’s arp into reply-only and it does the same thing as slackR. My ipv6 works for a while then suddenly stops working, I think as long as i’m pinging something via ipv6 to keep the neighbors fresh it’ll continue working then when the neighbors go stale it becomes an incomplete neighbor. If you have a windows based machine to test with try disabling arp (or set it to reply only) on the router and do this from an administrator command line. “netsh int ipv6 delete neighbor” then try and see what happens. Or just give it a few minutes with no activity on the machine for the neighbors to be lost.
I have did some more testing and came up with the same results. If I set ARP to anything other than enabled the ipv6 connectivity drops. I even reloaded two of the devices with netinstall and tried again with a minimal config. The only thing I haven’t tried is adding a loopback bridge interface like you show in your setup. I did notice the interface flaps when you change the ARP. I did check the interface stats, disabled then enabled. Even rebooted each routerboard with the same results.
I do have console/serial access to all the routerboards. I also built some supout files before and after I have changed ARP on the interfaces and sent them to support.
[slackr@450G] > /system resource print
                   uptime: 4h54s
                  version: 5.6
              free-memory: 238924KiB
             total-memory: 257120KiB
                      cpu: MIPS 24Kc V7.4
                cpu-count: 1
                 cpu-load: 1%
           free-hdd-space: 485388KiB
          total-hdd-space: 520192KiB
  write-sect-since-reboot: 1895
         write-sect-total: 1895
               bad-blocks: 0.1%
               board-name: RB450G
                 platform: MikroTik
[slackr@AP-433] > /system resource print
                   uptime: 7h50m19s
                  version: 5.6
              free-memory: 50180KiB
                      cpu: MIPS 24Kc V7.4
                cpu-count: 1
                 cpu-load: 2%
           free-hdd-space: 35972KiB
  write-sect-since-reboot: 5185
         write-sect-total: 2108199
               bad-blocks: 0%
               board-name: RB433
                 platform: MikroTik
[slackr@450G] /ipv6 neighbor> print detail where status="failed"
Flags: R - router
 9   address=2001:470:b0ab::9 interface=ether2 status="failed"
10   address=2001:470:b0ab::8 interface=ether2 status="failed"
[slackr@AP-433] /ipv6 neighbor> pr
Flags: R - router
 0   address=2001:470:b0ab::9 interface=ether1 status="incomplete"
[slackr@AP-433] /ipv6> /ping 2001:470:b0ab::9
2001:470:b0ab::9                                        timeout
2001:470:b0ab::8                          104  64 638ms address unreachable
    sent=5 received=0 packet-loss=100%
I concur. I have verified on both 5.8 & 5.9
I have a:
Windows 7 → Virtual Wifi → Bridge → physical port → linux box
Soon as ARP is disabled on the bridge port … all pings drop. If disabled on the virtual wifi port and the physical port … all seems to continue to operate correctly. The bridge needs ARP for some reason.
The network is IPv6 Only … no IPv4 addresses.
upgrade to 5.12 when released this problem is fixed, or write to support to get testing release.
Will be also this issue related to IPv6 ND and ARP mode on interface fixed, please?
http://forum.mikrotik.com/t/ipv6-nd-not-working-with-interface-arp-mode-reply-only/51426/1
Thank you
as i understand it - yes, this is the same issue. IPv6 stopped working with arp=disabled
Mentioned topic was about that when I configure arp=reply-only, the IPv6 stateless autoconfiguration was not working to clients, also neighbour discovery was not working.
Is there any schedule when will be the final version of 5.12 relased, please?
Thank you
soon. ND did not work due to problem with ARP that caused IPV6 to not to work at all. Starting with ipv6 LL address in the router.
In the mean time you can get test release if you write request to support.
The first tests shows that the issue with interface ARP mode reply-only and IPv6 stateless autoconfiguration is solved, I’m looking forward for final release of 5.12 :slight_smile:
