babine
1
I am quiet new to the Mikrotik environnement and i want to disable BPDU sending frame on one port.
I found the command in the manual, but i am not sure about the dst-mac-address.
I need to put the mac address of my out-interface ?
/interface bridge filter
add action=drop chain=output dst-mac-address=01:80:C2:00:00:00/FF:FF:FF:FF:FF:FF out-interface=ether1
It’s maybe a stupid question, but i want to be sure.
Thank
nichky
2
if you want to disable BPDUs on specific port, just use this command:
add name=bridge1
add bridge=bridge1 interface=ether1 bpdu-guard=yes
“In this example if ether1 receives a BPDU, it will block the port and will require you to manually re-enable it.”
babine
3
But i don’t want to block the port.
My purpose is to stop sending BPDU and ignore receiving BPDU on a port.
tdw
4
Set edge=yes for the interface bridge port. I do not recall when this feature was added, it is mentioned in the help pages but not the old wiki.
babine
5
Thank you for your return.
Should be good now. To test it, i imagine i have no choice, i need to make packet capture ?
