Disable dhcp ethernet (not wifi)
I would like to disable DHCP for connections using Ethernet but I would like keep DHCP for wifi, is that possible?
Thanks.
If you have both in bridge for DHCP. You can use bridge filter to allow only DHCP request in WIFI interface
Here is a post that will help you
https://aacable.wordpress.com/2013/02/22/howto-block-dhcp-traffic-via-mirkotik-bridge/
Thanks for reply. I finally did with separate bridge, keeping “bridge-local” inactive.
Out of curiousity…Why would you need this distinction?
