Is there a way to disable this deffault “Drop all not coming from LAN” rule somehow using script/ maybe autorun script (if it is possible) after hardware reset.
It is very important, as i will need to upload my config script to 20-30 devices at a time, and i may do it using API (java api), but for that i will need to connect directly to each router device via wifi or ethernet and to disable this rule manually. It is not very convenient, but i may do that. And if we are talking about users with general knowlanges It is not an option…
Do not disable that rule!
Insert an “accept” rule above it with src-address equal to your IP address on internet.
That way you have access, but the rest of the world cannot easily walk in.
Thank you for such a fast an answer and tip!
Any way i will need to connect to each board for adding a new rule.
Maybe you or someone may give a tip of how to do it Like it is doing with autorun on windows (just connect some usb with autorun in the root of storage and it is picked up … )
You will have to think about your rollout plan!
There are several ways to set standard config, e.g. by specifying a config file during netinstall.
There is no “simple trick to override the firewall from remote”, for obvious reasons.
Thanks. As an option for uploading my config script and add a startup schedule i have connected all routers to the same switch in same sub network.
But it is really good only for the first installation. And not for the reconfiguration after hard reset…
Going to check what is netinstall and how it may help me.
check this may help you
http://forum.mikrotik.com/t/accepted-interface-in-filter-by-script/117893/1
do you mean with public ip?
if so, what to do with a dynamic public ip?
