I would like to be able to enabled and disable SSIDs that are provisioned by the CAPsMAN like this:
/caps-man interface disable \
[/caps-man actual-interface-configuration find \
mac-address="2C:C8:1A:42:2A:2B" configuration.ssid="myssid"]
However, I am getting this error message: “failure: interface managed by CAPsMAN”. I am using the local forward mode. I also tried /caps-man interface.
I found a solution:
Disable with:
/caps-man interface remove \
Re-enable with:
/caps-man remote-cap provision [/caps-man remote-cap find base-mac="2C:C8:1A:42:2A:2B"]
Though this re-enables all interfaces on that CAP. In my case that is OK because I only want to switch one particular SSID.
Interface configuration can indeed not be enabled/disabled.
Provisioning rule however can be.
If you can make a separate provisioning rule for that specific need, it should be possible to toggle its status.
I am not a fan of deleting but that’s me.
A disabled rule tells you a lot more then something which is not there anymore.
Good to know. But would that mean that I would have to make like 40 provisioning rules (5 Ghz and 2.4 Ghz for each of the 10 hotspots and for each of the two SSIDs)?
Currently, I only have two rules!
Also, wouldn’t this turn off all SSIDs since multilple SSIDs are implemented using slave configurations. Or can I define multiple master provisioning rules to get multiple SSIDs on a each AP.
A major downside of disabling/enabling an SSID via interface deletion and re-provisioning is that re-provisioning briefly takes out all SSIDs. I may instead enabling/disabling switch rules.
One also needs to keep in mind that only slave configs can be deleted without deleting everything.
If you wanna turn off an SSID… call for the SSID.
I get an error that it is managed by CAPsMAN.
To keep it easy… Name the interface with the SSID.
Then use the find function with a ~. This will find BillsLVR and BillsMBR. ~“Bill” will apply to all interfaces with the word Bill in it.
Then disable find ~“Bill” in interfaces.
That would shut down the virtual APs that have that name in them.
In which menu would I then disable one particular slave SSID?
It seems I might get more control by using static instead of dynamic interfaces in CAPsMAN, but then I would have to do my own naming scheme.
Either you manage through capsman, only one place to be but then you can not manage anything locally.
Or you manage everything yourself but then it needs to be done on each device separately.
If you only have a limited number of APs, you could go for the second option.
I read somewhere the rule of thumb (not set in stone) is 3 to 5. Below, don’t bother using capsman (unless for educational and WBIC-reasons
*WBIC: Why ? Because I Can !
For me N = 15, so CAPsMAN seems well worth it. And CAPsMAN appears to allow for either static or dynamic provisions. The static ones can then be reconfigured on each devices separately after they have been provisioned as they are actually stored on the CAP devices, whereas the dynamic ones only exist when connected to the CAPsMAN; but one does not get automatic naming with static provisioning, I think (actually not sure about that, but it was mentioned in some forum thread).
