Disable/Hide buttons
Hi, is there any way to disable or hide the button that is shown on the attached image?
Best regards,
Paulo Brinca.
I just stumbled on another RouterOS configuration page (searching in google returns plenty of results) that has the same RouterOS version and has been changed, having the webfig login form:
I want to be able to access the configuration page over the internet, but i don’t need my graphs to be public :frowning:
Just set them to be allowed from specific (internal) addresses only.
/tool graphing interface/resource
add interface= allow-address=
That is a start, as it disables the info to be shown.
But what i really want is to be able to customise the initial page, so i can be able to decide what i want to be displayed.
As shown on the second image, that user has the login form, and my system doesn’t.
Best regards,
Paulo Brinca.
I have seen this also, but I was using standard RouterOS npk files on all routers, and for some reason the pages were different.
I do not know of a way to change the web page. You could ask MikroTik support http://www.mikrotik.com/support.html
in older versions we did not have the login form. upgrade to v6.6 to have it.
or reinstall the router, in case the webpage has been customized by the vendor.
Hi Normis, this is a x86 machine, and it has been originaly installed with version 2.?.? (not shure what’s the exact version) and upgraded since then.
In the earlier posts i have share a print of my access and another one i found online.
As you can see, both the devices have RouterOS v6.2, and as far as i know, your Portuguese vendor, Officelan, doesn’t change anything.
So, back to my original question, is there any way to edit that page or not :laughing: ?
Best regards,
Paulo Brinca.
