Disable IPv6 ND per interface
Hi there!
I'm troublehooting and issue in IPv6 where I learn more than one default GW, introducing conflicts. I have a ISP that uses PPPoE and I learn a DGW via PPPoE and also via the WAN (parent interface). I ended up disabling "accept router advertisements" on the Ipv6 general settings. But is there no way to control this per interface or interface lists (enable/disable RA)?
What about this?
Aside from the above, I would also contact the ISP to mention that they have this wrong configuration on their network.
When using PPPoE, there should not be an RA on the raw network interface.
You are right, I might need an upgrade to have this option. Thanks for pointing this out!
Agreed, but I'm using their CPE in bridge mode which is not really supported by the ISP.
