hi, we have a user manager on ros 4.17.
The problem is that logs and sessions fill all the available disk space, the we can’t do nothing like delete or add user and also logs!!!
i think that mikrotik MUST fix this because i can’t delete 20000 log records every day! I must have an option to disable log, to set a max amount of MB that log can use or to set a time range like “log only from 2 hours ago”.
Please someone hlep me if know how to disable logging or another solution.
