Disable Manual upgrade in Mikrotiks
Hi, I need your help, im administrating various mikrotik hardware, how to prevent other administrators from updating mikrotik, an example, im upgrading all the mk´s to the version 6.44.5 Long Term, the other administrators are upgrading other mikrotik to 6.45.6 stable, i dont like it, how to disable the option to upgrade?, An Script?, thanks in advance! :smiley:
Talk with the other administrators and both agree on what version to upgrade your routers…
Probably the best advice:
But, if you control the other routers, you can restrict the permissions. I think upgrade is a “policy” right so if you assign the admins to a group without that permission, that might work too. See: https://wiki.mikrotik.com/wiki/Manual:Router_AAA
Thank you!1
