Disable NAT on VPN connections
Hi All ,
I am trying to setup Mikrotik as a internet gateway ( through pppoe) , Also external users can connect using vpn to mikrotik to have access to office computers but they shouldn’t have internet access using vpn connection …
what is working :
dhcp and internet access for local users are working fine.
I can connect to the mikrotik using pptp vpn …
what is not working :
I have internet access using that vpn connection ..
I don’t have access to the local office computers
mikrotik ip : 10.10.10.1
office local ip range : 10.10.10.10 - 10.10.10.100
vpn ip range : 10.10.10.101 - 10.10.10.150
how can I exclude vpn ip range from being routed to the pppoe connection ?
Use filters in the forwarding chain of IP Firewall.
To access the local LAN you probably need Proxy-ARP running on the LAN interface and to allow that traffic in the forwarding chain.
