Disable NAT use WAN DHCP for lan ports, WAN WiFI
Hi, I have a Routerboard RB951ui-2hnd, and I want to disable NAT and DHCP server for the LAN ports, I have it Connected to a WiFI router via WLAN, so basically I would like to disable NAT for the LAN side and use the DHCP from my WAN router, basically using the Mikrotik as a Bridge, but i want to eliminate the Double Nat that is going on now, can some one guide me to do that?
thank you!
Ivan
Put wlan interfaces in same bridge. Setup wireless security profile and connect to router.
Or put them in the same switch group
Sent from my SCH-I545 using Tapatalk
And then bridge the master-port with the WLAN interface!
is this setup working OK?
I’m trying to do the same, and it works fine if I only have one device connected to LAN port of the MikroTik router. Once I connect more devices it does not work any more. Any idea why?
The Mikrotik WLAN is connected to the WiFi router and the WLAN interface is bridged with the LAN ports.
Peter
post an export…
