Disable POE & Boot / CCR1009-7G
Is there a way to disable PoE and Boot on eth7 on a CCR1009-7G-1C-1S+? The port is labeled as “POE/BOOT” and I would like to use it just as a normal eth-Port (such as eth4 for example), without PoE and PXE/Boot (or what it is).
I didn’t find any way to disable the PoE on this model.
Thank you in advance.
