Disable Queue's fixed problem
Hello
Has anyone see a router that works fine for days but them stops routing.
Reboot does not fix but disable/re enable queue fixes problem?
V 3.13
Edit I am not alone http://forum.mikrotik.com/t/pcq-issue/24239/6
MOre info.
I am npt sure it is the Queues hat fixes it.
When I disable NAT it does.
