disable running check in latest RouterOS?
Hi guys! where is the disable running check in latest RouterOS?
What do you refer to with “disable running check”?
Are you referring to this:
https://wiki.mikrotik.com/wiki/Manual:Tools/Profiler
i refer to this https://wiki.mikrotik.com/wiki/Manual:Interface/Ethernet
disable-running-check (yes | no; Default: yes) Disable running check. If this value is set to ‘no’, the router automatically detects whether the NIC is connected with a device in the network or not. Default value is ‘yes’ because older NICs do not support it. (only applicable to x86)
but now i see is only applicable to x86. I thought could be useful in some cases
Yes, this feature is available only on x86 machines:
[admin@MikroTik] > :put [/system resource get architecture-name ]
x86
[admin@MikroTik] > interface ethernet set disable-running-check=
no yes
