Hi
I need to disable all SNMP requests The Dude sending. I only whant it to ping.
Is it posible? I have disabel all funktions I can find related to SNMP but it still send some.
Can I switch it all off in config?
To disable SNMP you should make no-snmp as a default profile.
And also check if all the devices are set to use default SNMP profile.
If you have auto scan procedure for your map it will use any defined SNMP profile during scan. To disable it you should delete all the other SNMP profile exept no-snmp profile.
