disable users to use ping, but allow to be pinged
i have this
add action=drop chain=input disabled=yes dst-address=10.10.10.0/24 protocol=\
    icmp src-address=!10.100.0.100 src-address-list=BlockLAN
add action=drop chain=forward disabled=yes dst-address=!10.100.0.100 \
    dst-address-list=BlockLAN protocol=icmp src-address=10.10.10.0/24
and in this scenario neither i can ping pc inside this network, neither in different direction.
What can i made to allow me to ping pc inside 10.10.10 network, but still disable them to reach to me.
You need to match on ICMP type and code. Search for “icmp-options”:
https://wiki.mikrotik.com/wiki/Manual:IP/Firewall/Filter
add action=accept chain=input disabled=yes dst-address=10.10.10.0/24 icmp-options=8 protocol=\
add action=accept chain=forward disabled=yes dst-address=!10.100.0.100 icmp-options=0 \
this also didnt help, if i understand good, icmp-option 0 will block icmp and 8 to allow, so first action will allow ping from my BlockLAN list (its list of private subnet that need to reach that subnet 10.10)
Without reviewing the details… Both rules have “action=accept” and will never block anything.
You want hide the RB? use only input, dropping incoming (on input chain) echo request, but if something is pinged from the RB, surely the destination will know that the RB exists, MAC included.
You want hide the PC trough the RB? Is sufficient only one rule on forward chain that drop echo request from IP not = to the IP on PC.
And again: If something is pinged from the PC, surely the destination will know that the PC exists, MAC included.
But I discourage any dummy block of ICMP…
WHY? Is there a real problem being encountered or are you off your medications?
:question: is for @tomislav91???
jajaja not for you rextended, you are beyond hope :wink:
@tomislav91 why do you want to do this?
Unless you have a really good reason, leave ICMP (including ping) alone.
