Hi all,
In order to prevent black hole I would like do disable WiFi when the LAN connexion is lost.
For example Ubiquity can monitor connexion and disable WiFi consequently.
Do you have any solution for that with mikrotik ?
Thanks.
Jeremy
Hi all,
Thanks.
Jeremy
Yes, there are different options how you can achieve it.
One of them to configure netwatch, and monitor default gateway IP address (the same IP address as your LAN/Ethernet interface has).
/tool netwatch
add down-script=“/interface wireless disable wlan1” host=159.148.147.196
up-script=“/interface wireless enable wlan1”
host is your default gateway.
Thanks for your help
If you use CAPsMAN this happens automatically when connection to CAPsMAN is broken.
JF.
