hello,
i have MT 2.96 with 3 wireless interface i want to make a script on netwatch to check for an ip if it’s down i want to disable and enable the wireless interface “client”. can anyone write it for me plz.
best regards
you need to be more clear
why u need to disable ???(u can move load) and if the interface disable how it will check ping ![]()
Gotta be kidding
Is $40 too much? Esp if your using it for commercial purposes.
If I had the power i’d ban your ip from visiting the forum. But thats just me…
dear friend,
my wlan sometimes get disconnect when i disable it then enable it it reconnect again so when it’s enable it and connected i want to use netwach to watch the ping for this interface when it disconect the ping will be lost so i want to put script in netwach to disable then directly enable the interface to get it reconecting again.
best regards.
buy a license first, ok?
