Any ideas on why I am not able to enable the wan1 port?
Mark
Mark
What RouterBoard for you have?
What RouterOS?
Try to do a default config. It should be enabled by default.
2SHPn
routeros-mipsbe-6.40.5
I reset the configuration and made sure the no default configuration was not checked. And it says port disabled. But if I look at wifi it will show me all the wifi networks around me?
Mark
If I connect to the MikroTik by wifi it shows designated port. If I connect to it by wire. It says disabled port? Is this normal?
Mark
Mark
Found it. I was a duh moment.
Mark
