disabling dynamic routes
hi everyone
i have a rb433 on which i need to do source nating with masquarade for 3 pppoe account
the 3 pppoe accounts should be connected througth the 3 ethernet interface
than the nating should be from ether1 to wlan1 , ether2 to wlan2 and ether3 to wlan3
the problem is that when i try to connect these 3 pppoe the dynamic routing is ruining everything
so any idea if possible to disable the dynamic routing or any other way to do my project with a single routerboard
thanks for every reply
If routing is ruined by default route added with PPPoE interface, you can disable default gateway add, by
interface pppoe-client set add-default-route=no
If routing is ruined by the IP addresses added to the tunnel, when appropriate entry is added to the routing table. Reconsider your network structure, whether IP addresses assigned to tunnels, IP address configured on the router or static routings rules you have.
problem should be from the default route added with PPPoE interface
i ll be trying your solution very soon and i ll feed u back
thank u for your help
