I have MikroTik Cloud Router Switch running v6.12. I have the following problem:
The network has static public IP, example 1.2.3.4.
Whenever I or anyone access 1.2.3.4 via public, they get the MikroTik interface to login:
I would like to disable this. So when someone visits the public IP, they are unable to see the login screen or login at all.
No, you won’t; you’ll have to use winbox for management, which BTW is a much better option (layer2 support, RoMON, multiple windows, session saving, etc).
If you want to keep using webfig, use either the second of third option.
I second what sash7 said, if you were using the default firewall ruleset, your webfig won’t be available from WAN, you have to check that.
To post the ruleset, open a New terminal and issue
/ip firewall export
then paste the text here, edit out public IP for privacy if desired.
