Disabling rule
hello if u help me i want the command that allow me to disable a rule that i set it in firewall Nat (i redirect all dest port to 8080) now i can’t connect with winbox so i need to disable this rule to connect from winbox thank u
  1. On CLI, type ip firewall nat
  2. Use command print to see the redirection rule you want to disable
  3. Use command disable + the number of the rule, ej: disable 0
Regards
thank u very much it’s done
:mrgreen:
