disabling system -> package
Hi guys,
I have a question with system → packages here.
Let’s say I have configured something on /ip hotspot
Certainly there’s configuration there.
If I go to system → packages, disabled hotspot package and then reboot the router.
I cannot find the /ip hotspot config anymore
my quesions are:
  1. does that mean my /ip hotspot config is removed from the router due to the hotspot package absence?
  2. and if I reinstall the hotspot package, will my /ip hotspot config comes back?
bump.. anyone?
Very quick test with PPP package says that config for disabled package is not lost and comes back when re-enabled. You can enable your hotspot package and see if it works there too.
Thank you for your quick test and answer. Cheers
