Disabling2.4GHZ wifi
Hi all,
Is it possible to disable the 2.4GHZ wifi from the commandline?
I have upgraded all my home devices to 5GHZ wireless so want to turn off the 2.4GHZ wireless.
Pranav
/interface wireless disable wlan1
better this, do not matter if wlan1 is renamed, and disable only (all) interface(s) with 2GHz set:
/interface wireless disable [find where band~"2"]
Many thanks. The
/interface wireless disable [find where band~“2”]
did the trick.
Pranav
[pranav@ConShield] /interface> print
NAME TYPE ACTUAL-MTU L2MTU
0 R ether1 ether 1500 1598
1 RS ether2 ether 1500 1598
2 RS ether3 ether 1500 1598
3 RS ether4 ether 1500 1598
4 RS ether5 ether 1500 1598
5 XS wlan1 wlan 1500 1600
6 RS wlan2 wlan 1500 1600
7 R airtel pppoe-out 1480
8 R ;;; defconf
bridge bridge 1500 1598
