Disappearing GRE interfaces?
I have an x86 RouterOS v6.11 running on ESXi 5.1 with 2Gb Ram, 1 Cpu w/ 2 Cores and 2Gb Hdd thin provisioned. The problem I have is that the GRE tunnels keep disappearing on me. There are a few GRE tunnels running IPSEC between several remote sites. When the interfaces disappear the traffic typically stops flowing but this last time the traffic is still moving across the tunnels even though I can’t see them and all references in the configuration specify an ‘unknown’ interface.
Is this a known issue w/ a known fix?
support@mikrotik.com
Did u solve this issue !?
I got similar disappearing problems with EoIP and VLAN with v6.11 and v6.12.
No, I haven’t made any progress on this yet. I’m waiting on a reply from support.
I’m having this same issue on 6.12, neither winbox nor interfaces print shows the GRE interface, however if I try to recreate the interface it tells me it already exists.
please try the latest RC version, we have fixed an issue that might solve your problem:
Tilera: http://www.mikrotik.com/download/share/routeros-tile-6latest.npk
MIPS-BE: http://www.mikrotik.com/download/share/routeros-mipsbe-6latest.npk
PPC: http://www.mikrotik.com/download/share/routeros-powerpc-6latest.npk
X86: http://www.mikrotik.com/download/share/routeros-x86-6latest.npk
SAME ON PPC
Sorry wanted to clarify Actually my EOIP interfaces are dropping off
