How to disassemble display unit on RouterBOARD 2011UAS-2HnD-IN case? I need to get access to LCD but plastic housing looks pretty fragile and I am afraid of breaking it apart.
You can remove the top cover of RB2011 to access the LCD from the under side. Why do you need to remove the LCD from the cover?
I need actually move LDC from the top to the opening on the front panel of customized case. Yes, I can access LDC from inside but still having some doubts what to push to have the entire set disassembled gently.
