Disconnect error every 10sec if pass via CRS305
Hi I do have issues with the CRS305-1G-4S+IN , used as a hub, very simple, no vlan stuff no nothing but got lot of disconnect error. The setup is :
Esxi box in 10g to the CRS305 and then a dac cable to the rb4011. On the esxi6.7 box i got about every 10sec error message :
Physical NIC vmnic1 is down.
Physical NIC vmnic1 is up.
But if the esxi box is direct to RB4011 via 10g. link is rock solid. Unit is powered via Dc1 and sfp1 and sfp4 is used. Also RB4011 did not return error in the log.
I did update the SWos of the crs305 to 6.49.7 , but still get same issues. So is there a way to check out or something like a power management that may affect or so ?
Thanks in advance
Did you get this issue resolved? How is the CRS305 powered, POE or AC adapter? What is the temperature reading from the device UI?
