disconnected, received deauth
It worked for me:
In the advanced wireless properties:
noise floor limit “-110”
adaptive noise immunity “both”
Disconnect timeout: 10s
in failure attempt time 0.10
in the wireless tab:
wireless protocol “any”
disable:
“multicast buffering”
“keepalive frame”
Remember to choose a good free frequency band and a good “target” antenna alignment.
Default authenticate not ticked . … Means … deny all authentication, unless ACL says otherwise (has an accept rule in local ACL) => authentication will fail even with the correct credentials and methods.
disconnected, received deauth: authentication not valid (2)
disconnected received deauth class 3 frame received (6)
disconnected received deauth class 3 frame received (7)
… as expected
ACL’s are not given in these posts! So it is not clear what’s wrong there.
Management protection secret is given but is wrong in the other attempt? => management protection failure
Some client devices require that WMM is enabled on the AP.
Wireless protocol is 802.11 (“any” includes “nstreme” and “nv2” , which are only understood by Mikrotik devices)
