VARELA
1
Hi.
I have bridge with wlan and ether interfaces.
PPPoE server is runing on bridge.
PPPoE clients disconnected when interface state going down
There is disable-running-check option for wlan, but for ethernet it is absent.
How can I fix this problem?
RouterBOARD does not have disable-running check for Ethernet ports, it works automatically.
Running state is removed, if cable is disconnected.
VARELA
3
Ok. But how can I fix disconnection problem?
Chupaka
4
have you set Admin MAC for the bridge? probably the problem is because MAC address changes when port flaps…
VARELA
5
Chupaka GURU!
Work beter, but sometims disconnect.
