Disconnecting users pppoe
Good, I have a problem with my PPPoE server, the users are disconnected very often (10-20) times a day, been reviewing the configuration and can not find the problem server configuration is:
/interface pppoe-server server> print
0 service-name="p2p" interface=bridge1 max-mtu=1410 max-mru=1410 mrru=disabled authentication=pap,chap,mschap1,mschap2
keepalive-timeout=60 one-session-per-host=yes max-sessions=0 default-profile=p2p
1 service-name="p2pno" interface=bridge1 max-mtu=1410 max-mru=1410 mrru=disabled authentication=mschap1,mschap2
keepalive-timeout=60 one-session-per-host=yes max-sessions=0 default-profile=p2pno
/ip pool print
0 p2p 62.82.175.129-62.82.175.254
1 p2pno 62.82.175.4-62.82.175.128
1 name="p2p" local-address=62.82.175.2 remote-address=p2p bridge=bridge1 use-compression=default
use-vj-compression=default use-encryption=default only-one=default change-tcp-mss=yes rate-limit=256k/1M
dns-server=62.42.230.24,194.179.1.100
/ppp profile print
2 name="p2pno" local-address=62.82.175.2 remote-address=p2pno bridge=bridge1 use-compression=default
/ip firewall mangle print
0 ;;; Cambia MSS
chain=forward action=change-mss new-mss=1410 tcp-flags=syn protocol=tcp
1 ;;; Cambia MSS ACK
chain=forward action=change-mss new-mss=1400 tcp-flags=syn,ack protocol=tcp
A greeting.
