Discover admin password
Can I set a default discover password for the dude?
So I’ll discover a fairly large subnet of mikrotiks, they have the same admin password. How can I have it so I dont have to go on every single one and enter this password?
It looks like its using a password as its starred out. But cant find somewhere to change the default.
Never mind. Looks like you can’t do this. BUT you can select all and right click edit the password of the selected. So this is fine.
There is a way. Open The Dude client, on the left click on Devices, then click on the RouterOS tab and select all of them and then right click on the highlighted box and click on Settings (NOT device settings, just Settings), then you can change the username and password there, and click apply, then OK, close the window, and all of them will be changed. This also works for all devices, even the non Mikrotik devices.
