discovery problem
Iam executing following discovery command via ssh ‘:put [/ip neighbor print value-list as-value]’. Iam facing two issues.
  1. This issue occurs more frequently. The command discovers all the devices but for some of the devices the ip address does not get populated. So I cant discover all the devices in my network.
  2. This issue occurs less frequently, the output of above command executed via ssh is truncated.
In our network we have mix of various mikrotik devices. The configuration of one device where this problem occurs is firmware version 6.44 (stable), boardname - hEX PoE, hardware 960PGS.
Is there any workaround for above problem?
Vishal
