Hi there,
I really like the discovery Protocol, but I also think that it increases my system security if every device broadcasts.
So would it be possible to define on which interface the discovery Protocol should work? I’ve got a management ring and only there it should be enabled.
Unfortunately that manual page has not been updated to the latest RouterOS.
When you have older RouterOS, it works like written there. When it is newer, you can select an “interface list”
there. First go to “interfaces”, create a list, add the interfaces you want to run MNDP on, then go back to discovery
settings and select the interface list you just created.
