Hi all,
I’m not sure if this is by design, but I have a Mikrotik RB951G-2HnD and use basically all the default config.
Only change I made was to diable the wlan.
But now I see a discrepancy between the webconfig and the winbox screens (in the QuickSet).
Winbox is saying that I have an “Ethernet” configuration, which I think is correct.
Webconfig is saying though that I have a CPE config and my IP adress is 0.0.0.0 and is displayed red.
The router is functioning perfectly well though..
Is this correct behaviour?
Thank you.
