I need some suggestions on parabolic dish antennas.
I’m looking for preferably 3ft, or otherwise 4ft 5.2-5.8Ghz Dual polarized.
thanks a lot.
thanks a lot.
what are you using the dish for, and exactly what type of advice are you looking for, link distance, card types?
If you are going to use a dual polarized dish you had best get a diplexer to seperate the 2 bands you wish to use, one that has good signal isolation.
Then you can use 2 cards on one router board 2 accomplish nstreme 2 off one dish.
Tranzeo has 5.8 diplexers which can be used for this, and you can get them from DoubleRadius.
I am unaware of anywhere else at this time.
Gabriel’s quickfire products are relatively affordable and offer two connectors on the feedhorn for both polarities. at the same time. We’ve got one on their 2’ dishes.
