disk backup
hello i just bought a ccr2116 and i put inside an nvme disk. i want to backup the entire nvme to an external usb hdd? how is this possible. and for the best if there is a script that will autobackup with current date and time it would be perfect.
anyone???
It is difficult because the file management possibilities of RouterOS are limited.
Probably best is to share the disk to a PC on the local network (using IP->SMB or the optional rose-storage package for NFS etc) and then run a backup program on the PC.
