I have a couple dozen devices with 16MB of memory - cAP ac, wAP ac, hAP ac2.
When I tried to upgrade from 7.6 to 7.7, I noticed that there was no free space.
Example:
system/resource/print
uptime: 37m26s
version: 7.6 (stable)
build-time: Oct/17/2022 10:55:40
factory-software: 6.45.9
free-memory: 53.0MiB
total-memory: 128.0MiB
cpu: ARM
cpu-count: 4
cpu-frequency: 448MHz
cpu-load: 0%
free-hdd-space: 0
total-hdd-space: 15.2MiB
write-sect-since-reboot: 629
write-sect-total: 5125597
bad-blocks: 0%
architecture-name: arm
board-name: hAP ac^2
platform: MikroTik
file/print detail
0 name="flash" type="disk" creation-time=nov/17/2021 03:30:43
1 name="flash/skins" type="directory" creation-time=jan/01/1970 02:00:19
2 name="flash/pub" type="directory" creation-time=nov/17/2021 03:30:43
There are no user files. It looks like the “invisible” part of the disk is full. Most likely (possibly) - some temporary files that are hidden from the user.
Everything is fixed quite simply - /system reset-configuration no-defaults=yes skip-backup=y
Or in general - netinstall.
Followed by entering text commands from the backup.
This is not very convenient, because. you need to go to the objects and connect manually with a laptop to each device.
A possible cause of this problem could be a power failure.
It is strange, that the firmware update procedure does not clear this “hidden” area from “extra” files. For example, “normal” devices after upgrading to 7.7 have about 11% free space.
I have cAP ac which have 8%, 7% etc. free space.
