Disk crashed on my MT router. It became unreadable.
I have last configuration backup, but, when i tried to load it on freshly installed MT (same version, same configuration, just disk replaced), MT reported that backup file is invalid, too short.
When I open file in hex editor its structure looks fine to me (compared to backup from otjer MT). Is there a way for me to convert backup file to some human readable form to see the configuration and set my router manually?
That is why I make a /export backup as well as a normal backup … I’ve had a corrupted backup file once before also … not sure there is much you can do to recover it.
I would do it if I knew that regular backup is not reliable. I do expect taht this is just ustom binaty format and there is a way to read values back. I guess it is closed format. I do not understand why it is binary at all, when it is not secured enyway (all paswords are easy visible with any hex editor).
buy the way how do you save /export? All I could get is result printed in console and then copy&pasted to file…
When I first started backing up our Mikrotiks I was just backing up them up and then ftping the file off to another server. When I ftped the backup back onto the Mikrotik it would give me the file to short error. I modified my script to use ftp in binary mode for the transport and I used binary mode ftp to upload the file again and then it worked with out any errors. I have only really tested this once and it worked then so I am not sure this is the fix but it did work for me.
