Disk FUll
Hellow I have mikrotik rb450 and it shows that %6 of memory is free but there isn’t anything in the files folder and there isn’t any unneccessary file or package in it why could it be full filled ? what can I do to repair it ?
Do you maybe have an excessive amount of logs stored on the router?
I don’t think that they would be 30 mb much logs :S because Im using another system which has got much much more log and sessions on it and it only takes 1 or 3 mb space but I mean 30 mb nealry disk is unusable what can I do can anyone please help me ?
Have you CHECKED for logs? You’re having people guess as you’re not providing ANY information whatsoever.
Post the output of “/file print”, “/system package print”, and “/system resource print”.
Flags: X - disabled # NAME VERSION SCHEDULED 0 system 5.8 1 advanced-tools 5.8 2 wireless 5.8 3 ppp 5.8 4 routerboard 5.8 5 X ipv6 5.8 6 routing 5.8 7 security 5.8 8 dhcp 5.8 9 hotspot 5.8 10 mpls 5.8 11 ntp 5.8 12 routeros-mipsbe 5.8
file print
NAME TYPE SIZE CREATION-TIME 0 hotspot/lv/… .txt file 3 749 jan/01/2002 03:06:35 1 hotspot/img directory jan/01/2002 03:06:34 2 hotspot/ima… png file 5 043 jan/01/2002 03:06:35 3 hotspot/ima… .png file 7 113 jan/01/2002 03:06:34 4 hotspot/ima… .png file 7 650 jan/01/2002 03:06:35 5 hotspot/lv/… .html file 1 475 jan/01/2002 03:06:35 6 hotspot/lv directory jan/01/2002 03:06:34 7 hotspot/lv/… .html file 3 408 jan/01/2002 03:06:35 8 hotspot/alo… .html file 1 293 jan/01/2002 03:06:34 9 hotspot/ima… .gif file 60 jan/01/2002 03:06:34 10 hotspot/ima… .gif file 336 jan/01/2002 03:06:34 11 hotspot/log… .html file 6 149 jan/01/2002 03:06:35 12 hotspot directory jan/01/2002 03:06:34 13 hotspot/ima… .swf file 129 420 jan/01/2002 03:06:35 14 hotspot/ima… .gif file 599 jan/01/2002 03:06:35 15 hotspot/lv/… .html file 1 843 jan/01/2002 03:06:35 16 hotspot/lv/… .html file 2 760 jan/01/2002 03:06:35 17 hotspot/ima… .png file 13 223 jan/01/2002 03:06:35 18 hotspot/md5.js .js file 7 218 jan/01/2002 03:06:35 19 hotspot/rad… .html file 1 481 jan/01/2002 03:06:35 20 hotspot/red… .html file 213 jan/01/2002 03:06:35 21 hotspot/ima… .png file 1 223 jan/01/2002 03:06:34 – [Q quit|D dump|down]
uptime: 12h21m18s version: 5.8 free-memory: 39552KiB total-memory: 62196KiB cpu: MIPS 24Kc V7.4 cpu-count: 1 cpu-frequency: 300MHz cpu-load: 21% free-hdd-space: 4200KiB total-hdd-space: 61440KiB write-sect-since-reboot: 28603 write-sect-total: 2228458 bad-blocks: 4.2% architecture-name: mipsbe board-name: RB450 platform: MikroTik
And also I tried to clean the database but I wrongly uninstall the user manager and because of the capasity problem I cant install it again so that I cant clear it is there another way?
It’s definitely the UM database.
Search the forums, this has come up many times before.
But ı deleted the um and I havent got enouıgh memory to install so I cant clean it up what can I do ? :S:S
I don’t know, I don’t use User Manager. Other people in this forum do. They have had the same problem (I remember reading about it). If you search the forums for your problem you’ll come across one of those topics, and it will probably contain a solution.
thank you very very much
